AEG 66600 E60 Fault code
  • #50399
    bobnorris
    AEG Washing machine 91400308900.
    The customer says the machine wont start and displays fault code E60 which is not listed in the Whitegoods handbook, or on the website.Can anyone help who has seen this code before?
    Cheers Bob.
    #304692
    Re: AEG 66600 E60 Fault code
    if you are in normal operating mode you will normally only get an approximate fault code
    ie e60 could be e61 e62 e66
    you need to go into engineering mode to get which one
    all are heater faults
    e61 not enogh heat in wash
    e62 overheat during wash
    e66 heat element poer relay faulty
    if you want the manual let me have your email
    bobnorris
    I’d never have guessed the answer to this one.The wall socket was burning up and dropping the voltage to the machine. Fitted new plug and plugged in another socket and hey presto.Thanks for the advice on the fault codes dave.
    Cheers bob.
