AEG 72630
  • #11796
    mbdas
    HI
    im going to one of these later the fault is when they select Quick wash the time indicater is 57 mins and by the time it gets to 47 mins it stops with to main wash light on on the start/pause light flashing any ideas?
    pnc 91400209600
    thanks mark
    #146707
    mbdas
    Re: AEG 72630
    Have been to this machine yesterday and today machine fills up on a quick wash time 57mins remaining and gets to 47mins and starts to heat after about 5mins it then indicates 46mins left and jumps back to 57mins and the wash light and start /pause light flashers.
    first visit the last fault code was E53 insulation in the motor was 20megs cleaned the motor and fitted new carbons insulation was 200megs the machine then worked twice customer said 😥
    second visit same problem but fault code changed to E52 insulation still 200megs cleaned pcb contacts seemed ok.
    Got a call this am still faulty 😥 😥
    motor or pcb ? or both can anyone show any light on this 💡
    thanks mark
    #146708
    Re: AEG 72630
    Mark,
    Both fault E52 & E53 are associated with Motor failure. Whilst I have not had such problems with one of these and reading about the insulation problems you have experienced so far. I can only conclude that the motor is the guilty party 🙁
    #146709
    mbdas
    Re: AEG 72630
    Ive shorted insulation in motor out just carbon around brush holders.
    This fault is intermittent 😥 so wheather or not the insulation fault has caused the module to go faulty 😥
