Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › aeg 72630
- This topic has 8 replies, 5 voices, and was last updated 17 years, 2 months ago by
wilf.
January 30, 2009 at 12:16 pm #43014
wilf
Participantmachine sticking on program everything works fill both levels wash heat drain spin. I set the machine on a 40deg wash 80 mins in display and left it running. two hours later 37 mins showing and was still washing water was warm. I suspect main board but any ideas would help
wilf
January 30, 2009 at 4:37 pm #275684Martin
ParticipantRe: aeg 72630
OK Wilf I too would reach a similar conclusion were it not for the fact that the info you give is a little limited and vague to be honest.
Now ordinarily if all components and their respective connections to them are checked and double checked then it’s just got to be the programme module based on what you’re telling us.
And indeed if it were a component failure then the module would flag up an error code likely as not, with lights flashing and error codes on display. 😉
You’re not getting any such flashing lights then I guess? 😕
January 30, 2009 at 4:53 pm #275685wilf
first thing I asked the customer when they booked the call and they had noticed nothing. thats why after checking all the obvious I let it run and still no fault codes showing for me. as I say individually everything works as it should but through a cycle its on a go slow / stop
wilf
January 30, 2009 at 5:29 pm #275686Martin
Well again based on what you say I too can only conclude board failure but I put the odds as 50/50, suck it and see I’m afraid. 😥
January 30, 2009 at 7:15 pm #275687leavemetogetonwithit
I would think it sensible to look closely at the ntc if there is one, and heater element and connections and maybe earth leakage before investing in a module. If you haven’t done already.
Mike.January 31, 2009 at 6:40 am #275688Flyman
There has been no mention of going into diagnostics to see if an error code has been stored. Not all codes will show to the customer. Some errors will allow the programme to continue through to the end of the cycle.
January 31, 2009 at 11:49 am #275689wilf
heater and ntc perfect cant see how to get into error codes only into component testing.
wilf
January 31, 2009 at 12:09 pm #275690Penguin45
File landing in your in-box, Wilf.
February 2, 2009 at 11:22 am #275691wilf
thanks
wilf
