AEG 72630 – Cycle stops after filling
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG 72630 – Cycle stops after filling
  • #52682
    jrw
    AEG Oko Lavamat 72630 Update Washing Machine
    Machine takes in water to the normal level but doesn’t go any further through the cycle. My initial thinking was that it couldn’t be faulty water level detection else it would either not fill at all or not stop filling.
    The machine does not display any error code, just shows the number of minutes it expects to remain in the cycle.
    Tried it on cold program to determine whether it is waiting for the water to reach a certain temperature, but that shows the same symptom. So am back to thinking it is something connected with the water level detection. How does that work?
    Not sure if it is relevent but when you run the Pump Out program to get the water out it successfully empties the machine but the program never completes, just sits with 1 minute to go on the display.
    Any words of wisdom would be welcomed b/c I’ve also had my tumble dryer fail this week so I have my hands full.
    Cheers
    Richard
    #312735
    Re: AEG 72630 – Cycle stops after filling
    Is the drum turning?
    jrw
    Penguin45 wrote:Is the drum turning?
    Thanks for your time. No it doesn’t and there is no noise to indicate it is trying to run.
    I tried putting it onto a spin program. It makes a noise (motor or pump?) but the drum is not turning then either.
    #312737
    TheSpinDoctor
    Hi.
    I would suspect the motor brushes may be worn out.
    #312738
    jrw
    TheSpinDoctor wrote:Hi.
    Thanks for the advice……interesting that it doesn’t come up with an error. I guess it doesn’t monitor drum rotation.
    #312739
    TheSpinDoctor
    Hi.
    There will be a fault code in the memory of E52 usually in the case of worn brushes but this is not usually a code displayed to the user.
    #312740
    jrw
    Fitted new brushes tonight……sorted 😀
    Many thanks
