AEG 72640 (9140024081)
  • #82958
    rocker
    This machine showing fault code E40 Interlock clicks a few times but still works sounds like a interlock fault !! but I can’t find this code on fault finder.
    cheers John
    #421274
    Re: AEG 72640 (9140024081)
    E4? Errors relate to the interlock, you answered your own question.
    #421275
    rocker
    cheers Martin, any idea why its not listed on fault code chart!!
    #421276
    It displays as an error to the user only. Using the diagnostics routine (EMW1000 plus electronics) you get error codes from E41 – E45, all of which are interlock based errors as you know.
