AEG 72640 washer
  • #72002
    twicknix
    I visited this lovely washer this morning, a fine specimen if I may say! Looks brand new and so well looked after with the exception of mouldy door seal. It’s ten years old! A rarity these days.
    The product number is 911939001
    Basically it needs a new door seal, the one with the hole on the top to connect the pipe to, and a drain pump filter. I have managed to locate a new door seal after a lot of digging and probing.
    I know on the parts list that the drain pump need replacing as a whole but the only thing was wrong with it was worn seal and in my opinion a new filter screw is needed rather than a whole pump unit. Seems a lot of hassle to replace the entire unit just to get a new filter! Any suggestions?
    #383057
    Seamy
    Re: AEG 72640 washer
    Product number you quote refers to a dishwasher, after 10 years it deserves to be treated to a new pump. Theres an “O” ring listed for pump, 4006016697 but hazard a quess this is pump seal rather than filter seal.
    #383058
    DrDill
    I think the pump and filter housing has changed a few times over the years, if the filter seal is still intact but out of shape try dropping it in to a mug of boiling water and it should return to its original shape, failing that you will have to change the pump and filter housing complete.
    Sent from my iPhone
    http://www.kitchenkitsw.com
    #383059
    twicknix
    Replaced drain pump unit. Bit of a faff as it’s easier change the pump by removing front panel rather from the rear. Also this machine had a split hose from dispenser to tub. Wouldn’t have picked it up if it wasn’t for the heavy limescale deposits blocking the drain hose as I had to make a third visit to rectify it.
    Glad to have resolved it in the end.
