AEG 74620 C3 error
  • #78587
    brianmn
    Hello,
    My searches indicate that this is a water leak sensor issue. Others have suggested elsewhere that the sensor may just need cleaning. Can anyone give me some indication of where this sensor is located?
    The machine is an AEG Lavamat 74620 (914001311).
    Thank you for any assistance,
    Brian
    #406185
    Re: AEG 74620 C3 error
    This old girl does NOT have a water/flood sensor. More likely it’s a pump fault (knackered pump) or the pressure hose (part if the rubber sump hose) is blocked with gunge (trade term for shoosh)…. Have fun checking that lot out! 😀
    #406186
    brianmn
    Thanks for the quick response about the nonexistent leak sensor. I’ll focus my attention on pump and hoses.
    #406187
    brianmn
    I should have been more specific about the issue in my first post. The C3 error is displayed continuously and the pre-wash and mainwash lights are flashing. The 1200 rpm light is also on but that may not be part of the error code. If there is any additional info known about this code please let me know.
    #406188
    brianmn wrote:The C3 error is displayed continuously and the pre-wash and mainwash lights are flashing.
    Correct! See above advice.
    #406189
    brianmn
    Martin,
    Thank you very much for your help so far but I’m back for more!
    The hose from the sump up to the pressure switch is clear (I can blow air through it).
    I checked the resistance on the old pump and it read ~100 ohms so it seems OK. I also tried a spare pump I had but it didn’t help matters either.
    I also pulled the pressure switch and it clicks nicely in response to pressure and the contacts open and close when I put a meter across the terminals and pressurize the switch. I don’t know exactly which terminals to test together but each of the internal pressure switches seem to be working.
    I still have a C3 code and flashing lights. Is there a next step you can suggest?
    #406190
    The pump resistance should read between 150-170 ohms.
    #406191
    brianmn
    Thanks again! The spare pump I have measures 190 ohms but it didn’t make any difference when I swapped it in. I’ve ordered a new pump regardless but I’m not optimistic it will solve the problem.
    Whenever the machine is turned on I get a brief period of a normal display (program time) but it switches to C3 in about half a second. I’m hoping the control board is OK.
    I’m currently doing all this testing with the machine in a state of dis-assembly (top and front are off and water pump removed but electrically connected. Can the machine be tested in this way or do I have to re-assemble each time to test?
    Lastly, is there some peculiar reset process for this error. I’ve tried the typical ‘pre-wash + soak + short spin’ which always works for C9 errors but no success.
    #406192
    brianmn wrote:Lastly, is there some peculiar reset process for this error. I’ve tried the typical ‘pre-wash + soak + short spin’ which always works for C9 errors but no success.
    Exactly the same procedure applies to clear the C3 error but remember that the fault MUST be rectified first in order to do that.
    Error codes are not gospel, any outside factor could show a random code. So it is essential that any earth leak faults (for example) are located and eliminated. Also the main circuit board could also be at fault. Only until you have exhausted all options can you then conclude there could a fault with that though (last resort). 😀
    #406193
    brianmn
    I can’t say what started the problem but the motor looks to be damaged. I noticed that one of the brushes was chipped and maybe as the piece broke off it partially shorted something?? Regardless, the resistance across the various commutator bars is not equal although nothing is shorted or open. One of the commutator bars has what looks like a burn mark and this is where the resistance values are high (~80 ohms from this bar to either one beside it compared to 0.4 ohms between all other bars).
    Also, the motor control board (?; located on the floor in the back of the machine) had a burned trace on it. After repairing the trace the washer will now power on without the dreaded C3 error!
    I’m assuming I will need a new motor although I will bring it to a shop tomorrow to confirm.
    This is a 14 year old machine so getting a new motor over here in Canada won’t be particularly easy. I have seen used motors that are very close in specs except for being 50Hz rather than 60Hz and AEG part numbers are nearly identical: 645307300 (50 Hz) vs 645307301 (60 Hz). These are FHP motors. I don’t know of any reason why these motors wouldn’t be interchangeable as there is nothing inherent about the motor that is specific for 50Hz. I don’t know if the tachometer would function slightly different but if spin speeds were slightly off that would seem minor. Is there some key issue that would be problematic using the 50Hz motor?
    Thanks again,
    Brian
