aeg 74630-10
  • #42983
    this machine starts motor spins then stops
    fault code e52 no tacho impulses
    checked motor and wiring both ok
    am assuming new board or can they be repaired ?
    looking for confirmation of my diagnostic in case i have missed something stupid
    Re: aeg 74630-10
    Has the motor tacho come loose, a very common fault on Zanussi machines.
    Re: aeg 74630-10
    checked tacho magnet was loose but still turns and gives output
    Re: aeg 74630-10
    It should not be loose, it needs to be very tight. It will often unscrew and push the tacho coil of the end of the motor on some machines.
    Gives the exact symptoms you describe.
    Re: aeg 74630-10
    Dave,
    I’ve sent you some guf via email to help sort (large file so beware. 😉 )
    All the best. 😀
    #275592
    Re: aeg 74630-10
