Found them to go off on motor t.o.c going open circuit on long programmes. Basically the motor overheats & activates the over temperature protection. No signal back from tacho to p.c.b so it shuts down programme. After it cools down it will run again as f nothing has happened. Normally its a motor change, it should throw up an E52 fault in error codes if you check diagnostics.
