Aeg 75238-GA1 freezer
Viewing 15 posts - 1 through 15 (of 15 total)
  • #68502
    stevebunyan
    Does anyone have the service manual for the freezer. Keeps increasing temp to -6 then slowly climbs back to -12 over 24hrs has 2 ntc’s on evap which both have variable resistance according to temp change. The heater element has .18Kohms through heater and 2 stats at -6. Fan on evap doesn’t seem to run all the time but does kick in when it feels like it. Any ideas welcomed.
    Sent from Steves
    iPhone using Tapatalk
    #371331
    stevebunyan
    Anyone
    Sent from Steves
    #371332
    Re: Aeg 75238-GA1 freezer
    stevebunyan wrote:Anyone
    There’s only a wiring diagram available. 😐
    #371333
    stevebunyan
    Hi Martin
    Would it be possible to have a copy of it?
    Thanks in advance.
    Sent from Steves
    #371334
    stevebunyan
    Does any one know the part no. For the defrost element on this freezer. Connect came up with one which didn’t have the 2 stats attached but the original had 2 stats attached.
    Sent from Steves
    #371335
    stevebunyan wrote:Would it be possible to have a copy of it?
    I don’t see why not…. 😉
    #371336
    stevebunyan
    Im struggerling to find the correct Evap Heater for this. The existing has 2 stats on it and the replacement according to Connect (5045170758073) doesnt.
    Can any one point me in the right direction please.
    Thanks in advance
    #371337
    Criscold
    I don’t know if this answers the problem ?
    #371338
    stevebunyan
    Thanks, do I read that right? That the new heater does away with the two inline stats.
    Sent from Steves
    #371339
    Criscold
    I don’t know but I do know that some of the heaters come with the stats wired in complete with the element.
    Colin
    #371340
    stevebunyan
    The original has 2 black Lego brick size stats in line which makes me wonder.
    Sent from Steves
    #371341
    Criscold
    Have you got the pnc + Serial Numbers on this unit
    Colin
    #371342
    stevebunyan
    PNC 922045851
    S/N 54801209
    #371343
    stevebunyan
    This turned out to be the reed switch on the PCB not being activated due to the door dropping enough for the magnet in it not to activate.
    Thanks for the info Colin, you where spot on.
    Sent from Steves
    #371344
    robbo1973
    I have this machine playing up as well it runs ok then cuts out when it wants then pulls all the way down to -18 and it’ll be fine for a day or so then temp will creep up evaporate ain’t iced up and heater etc is closed circuit,originally I could here some chattering from the pc pb when it cut out the first time so I changed the pcb and it seemed ok for about 4days then started playing up again!
    Has anyone had any issues with these?
    Cheers chris
