AEG 76810 E20 error code
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG 76810 E20 error code
  • #96295
    hairgoneJohn
    I have a AEG Lavamat 76810 washer used by a friend. One of the springs holding the drum wore through its bracket on the drum and the drum leaned over as a result. I have drilled a new hole in the support bracket and now the drum is back to its correct position.
    However when I put the machine to a wash setting the code E20 ( drain problem) appears. If I use the spin setting the spin happens and then the E20 code appears. There do not appear to be any blockages and the pump rotor can be spun with a pencil. I have tried removing connectors and replacing them as I have read that sometimes dirty contacts can be the problem.
    It seems an unlikely co-incidence that I have two problems at once ( draining and the drum support). Is this likely to be a drain pump, control board or other issue please?
    thanks
    #462924
    when the drum was out of position did it damage the wiring harness ?
    hairgoneJohn
    hi
    Thanks. Not that I know of but I should check underneath the drum. Thanks for the tip.
    #462926
    I am assuming the pump does not run at all
    have you tried it on pump out only so you can hear the pump to see if its energising or not ?
    hairgoneJohn
    No. Pump is not draining. I suppose I should put it on drain and check voltage across pump ?
    #462928
    ok just wanted to make sure
    if there is no power to the pump the drum could have damaged the harness when it popped a spring and severed the pump wire. you need to follow the wiring harness and look for damage
    hairgoneJohn
    That’s a good point. The machine is elsewhere but I will check it next time that I am in the vicinity and report back.
    Thanks for your help. I really appreciate it.
    John
