AEG 76820 Error code 50
  • #72955
    andew
    My AEG 76820 runs part cycle before stopping with 5 beeps (repeating) and Error E50 code. The drum does rotate and the machine runs on a 40degree cycle (empty) without issue.
    Any ideas as to what’s going on or how to do further diagnosis?
    tks
    #386052
    repman
    Re: AEG 76820 Error code 50
    so when does it beep and stop?
    #386053
    andew
    When running on the 40-60 cycle. I’ve just run a drain then spin (with part washed clothes) and it works not problem, although it also stopped part way through the refresh cycle. Very puzzling…it does seem to be fuller of water than normal when stopping.
    #386054
    Obvious question but worth asking……have you checked the pump or filter for blockages? Also check the motor for possible worn out carbon brushes.
    #386055
    repman
    with the wash load in start a wash and check that the drum will rotate in each direction alternately
    #386056
    andew
    Yes, the drum rotates in both directions. It also drains (when on drain cycle) and I’ve checked the filter (bottom right)
    #386057
    repman
    #386058
    andew
    I have had a repair man visit.
    Bushes ok. Pump replaced. Machine will work on drain and spin cyclces but has the same problem when conneted to waste. Will run without problem when draining into a bucket (excpet for mehaving to swap numerous buckets of water of course). I have flushed the waste (high pressure hose) and no blockage and sink on same u tube drains in les sthan 1 minute.
    Get same error code when connected to waste. What’s going on!!! 😥
    #386059
    Seamy
    There coud be an earth fault on motor, carbons not making good contact, armature dirty perhaps, loose cable connection on loom somewhere.
