AEG 80820 not drying
  • #21222
    Chrisgal
    Hi, my AEG 80820 sensorlogic is heating the water but the turbo dry is only warm. any suggestions.
    thanks
    #190065
    Re: AEG 80820 not drying
    Can you post the pnc number on this one please, Chris? Should be on a label on the edge of the door. Can’t actually find a version of this with the turbo dry function…….
    Chrisgal
    Penguin45 wrote:Can you post the pnc number on this one please, Chris? Should be on a label on the edge of the door. Can’t actually find a version of this with the turbo dry function…….
    Hello again.
    The PNC No is 91123251903
    Model F 80820
    Thanks Chris
    #190067
    Not much info to be had about the drying side of things. Obvious question, is the fan running, is there a good draught? Given that the blower passes the moist hot air through a condenser, it should cool rapidly, so whatever draught you can feel shouldn’t be same as the internal temperature of the machine.
    HTH,
    Chrisgal
    Penguin45 wrote:Not much info to be had about the drying side of things. Obvious question, is the fan running, is there a good draught? Given that the blower passes the moist hot air through a condenser, it should cool rapidly, so whatever draught you can feel shouldn’t be same as the internal temperature of the machine.
    HTH,
    When the wash is over everythings still wet and cold ?
