AEG 86741 C9 Fault code
  • #48237
    nelson
    Called out to this today, I checked the known error codes to find C9 is a motor tacho / motor or brushes fault. Checked the motor, no faults found, Tacho intact, wiring ok and brushes nice and long…. Am I missing something? When the machine displays the C9 fault it also flashes the pre-wash and rinse+ leds (1 & 4 from top to bottom) is this indicating something else? Any help much appreciated.
    Cheers
    #296033
    Re: AEG 86741 C9 Fault code
    light indicate the same thing if display not there use light to get code
    from lux info
    c9 = tachometer pulses are missing
    check drive motor
    carbons
    tacho gen
    wiring
    fault is listed as can only used again after a test routinr is started coulb you have to go into test and out again to reset
    try hold prewash and sensitive buttons and keeping them pressed turn rotary knob to energy saving
    this should start a test prog and reactivate machine
    have got manual can emal it to u if you get stuck but may b next week full model of machine should be LAV86741
    hope this helps
    nelson
    Cheers Dave, I’ll give the test routine a try. 🙂
