AEG 86800 washing machine dead!
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG 86800 washing machine dead!
  • #49707
    jontymox
    Good afternoon all,
    As I’m pretty new to the business, I wondered if there was a common fault on the above machine.
    I have carried out an insulation test via the plug, and obtained a good reading.
    The terminal block, and microprocesser/pcb appear ok – not obviously burnt, although an Ohms test of the terminal block does produce variable resistances… is this normal?
    The machine is only around 5 years old, and appears to be in a vgc
    Appreciate any useful feedback, that may shed more light on the problem!
    Jontymox
    #300791
    Re: AEG 86800 washing machine dead!
    Full Pnc number would help.
    Are there any lights on at all ?
    #300792
    jontymox
    Hello,
    No, the machine is completely dead.
    Will obtain full serial number today.
    jontymox
    #300793
    jontymox
    The m/c is a Lavamat L 86800 Serial No: 44693014
    Also investigating a Candy Tempo Logic CBL140 with the same fault!
    jontymox
    #300794
    you really need the Pnc or Enr number for these starts with 914…….
    #300795
    jontymox
    Sorry, PNC 91400308600
    Hope this helps, as I’m struggling to locate the fault on both m/c’s
    jontymox
    #300796
    jontymox
    Evening all,
    Just wondering/hoping if anyone has any thoughts/ideas on above AEG w/m fault, as I’m at a loss as to cause of problem.
    jontymox
    #300797
    Sent you some stuff.
