Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › AEG 88070 open the tap
- This topic has 6 replies, 5 voices, and was last updated 18 years, 3 months ago by
lomawa.
December 21, 2007 at 5:11 pm #33191
lomawa
ParticipantCan anybody offer advice, please?
Our dishwasher is a few months old but cannot get an engineer visit until 31 Dec.
We get the message ‘open the tap’. We’re having problems with the water supply: lost supply a few days ago and now have lower than normal water pressure. The sink next to the dishwasher has running water.
Do you think we have a fault with the dishwasher?
Is there anything we can do to get the dishwasher working again?Feeling a bit desperate before Xmas!
Thanks for any suggestions.December 21, 2007 at 6:47 pm #237743petalpop
ParticipantRe: AEG 88070 open the tap
if the water board have been doing anything with the pipes i would turn off the tap to the dishwasher and undo it at the machine end and check the filter to see if it is blocked
December 22, 2007 at 12:20 pm #237744frananlaw
It may also be that the water pressue is below what the machine will work too as i belive in this model that it is minimum one bar which is why you are getting the error code 💡
December 22, 2007 at 1:09 pm #237745lomawa
Thanks for the replies.
We suspect the water pressure may be too low but the water board hasn’t managed to improve it for us yet.
We don’t think we can inspect the end of the pipe/filter because the pipe is fixed/wired with an integral safety valve- hope that makes sense!
Thanks again.
December 22, 2007 at 1:16 pm #237746don
ModeratorRe: AEG 88070 open the tap
frananlaw wrote:It may also be that the water pressue is below what the machine will work too as i belive in this model that it is minimum one bar which is why you are getting the error code 💡
1 bar = 8 litres per minute of flow from the cold tap if you want to check 😉
Don
December 22, 2007 at 3:07 pm #237747Del
It is still worth turning off the tap that supplies the dishwasher and checking the filter in the end of the hose that is connected to it, to see if there is any crud blocking it. This can very often happen after the waterboard has been working on the water main.
Remeber that if the fault is due to a blocked hose filter you may well be charged for the call when the engineer calls, irrespective of it only being a few months old.
This would be because the fault may be external to the machine, and not the appliance itself.
HTH.
Del
January 5, 2008 at 4:43 pm #237748lomawa
Just to let you know “open the tap” was caused by the water pressure being lower than 1 bar – everything is working again including the water pressure! but we did a lot of washing up over Christmas!!
