Hi. I’m trying to repair an AEG 88730 washer (pnc 914 002 098 02). It shows a C6 fault code. Looking on the net I gather this is a pressure sensor fault. I have checked for blockage in the pressure tubes. I have bought and fitted a new pressure sensor but machine displays C6 on any program after about 15 seconds. Does the machine need calibrating to the new switch (like Hotpoint)?
Thanks for info, I’ll try that. So much for relying on fault codes! I remember when Hotpoint started using I@{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}#sit dishwashers. A watervalve fault code was actually heater failure!!
