AEG 91123253403
  • #25139
    goosegreen
    Another AEG D/W fill fault. Called to the above model yesterday which was overfilling then going in to pump out. The machine has a 1 level pressure switch but this seems to be for a flood protection only, Any one know how water level is controlled?
    Regards
    goose
    #204645
    helo_75
    Re: AEG 91123253403
    doesnt it have an iwms takn on the right hand side?
    big plastic chamber (intelligent water metering system)
    usually full of crap leading to overfill, thats if its a zanussi type!!!
    hope this helps
    #204646
    goosegreen
    Re: AEG 91123253403
    helo_75
    Thats whats thrown me a bit with this one! it looks like a real AEG made machine, you know the one, removable lower back panel, red plastic flood protection switch fitted to base easy acces to element etc. Not like Zanus versions which go in to valve lock out for no reason at all. Didn’t have a lot of time when I called so will go back and have another look
    Goose
    #204647
    cab
    Re: AEG 91123253403
    does have an iwms.
    check your mail.
    cab
