Aeg 949592279 Ceramic hob.
  • #99970
    ray.t
    I have this hob that needs a new hotplate. I ordered a replacement and it’s not the same as the original one, the wiring is different.
    Would anyone have a wiring diagram for it please?
    The original has tags 1, 2 and 3, S, H, 1a and 2a. There is a link going from 2 to 1a
    The new hotplate has 2a, 3, 4 and S and H.
    I was going with,
    2a to 2a
    1 to 4
    3 to 3
    S to S
    H to H
    Anyone have any better ideas?
    Thanks,
    Ray
    #478698
    would need to see a pic of both plate connections
    all thats happened i would guess is the themal limiter has been integrated into the connection block
    we need to work out what the connections do to work things out
    start with the simple ones. on the new ring 3 and 4 are the end of the inner and outer elements
    which on the old ring looks like 1 and 3. so if as you say you connect 3 to 3 and 1 to 4 the only thing that can go wrong is inner and outer elements will be swopped
    the current link between 1a and 2 has been replaced by the yellow link.
    that leaves us with 3 wires
    one wire is the live feed to the ring
    the other 2 are the hot indicator lamp
    take your multimeter and measure continuity between the 2 reds. if yes then the green terminal comes from the simmerstat load output to power the ring. do a similar test on the old ring see which connection give you 0 ohms between the link wire and 1 of the other terminals. which ever one that is is the live feed to the ring. remove wires before testing in case of back feeds.
    the last 2 wires are only a sw for the lamp and it should not matter which way they go
    hope this makes sense
    ray.t
    Thanks Dave for your time, I will give it a go.
    Thanks,
    Ray
