AEG A75106GA Freezer losing temperature
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum AEG A75106GA Freezer losing temperature
  • #73760
    tally
    Hi All
    Last night the alarm on my freezer went off because it had dropped down to 11 degrees, i put the frostmatic on to put the temperature down again, this has happened again tonight at the moment its at 14 degrees. I assume it a hard fault on the freezer, does any body have an idea whats wrong and how much it will cost.
    Tally
    #388710
    Seamy
    Re: AEG A75106GA Freezer losing temperature
    Try a defrost for 24hrs, likely the fans either jammed with excess frost or worse case scenario its seized up & not circulating. Hopefully its not as serious as needing gas or compressor failure as this may deem it uneconomical to repair.
    #388711
    tally
    Thanks, can i see the fans to check visually if yes where are they please
    #388712
    tally
    Hi All
    Since my last post it want faulty again, an engineer came out and changed the main processor card at the top which houses the buttons,it has run ok for 3-4 months but has now started to freeze up again at the bottom of the freezer and losing temperature down to -11 overnight again. The last repair was about £150 with parts and labour luckily its under 5 year gaurantee. Had 3 repair visits now at what stage will they replace freezer ? Can i reject it ?
    anybody help with whats wrong with it
    PS just replaced my Siemens dishwasher with a AEG to match freezer in kitchen DOOH
    #388713
    tally
    Engineer coming today… so i have moved freezer out so he can get to it, there was a drop of water falling from the back of the freezer. blue water stain on floor at back and it looks like the copper pipe out of the back has blue stained water down the pipe that goes to the compressor.
    Anybody help please
    #388714
    tally
    engineer says defrost sensor needs replacing so it will be changed tomorrow, see how it goes, warranty runs out in October so if it happens after that it will be binned an a new one bought , not an AEG
