AEG AKO446 (old) D/washer
  • #66138
    Ancient beast, cannot find any info on TDS.
    AKO Favorit 446, Enr 606 281 195. Fnr 025 585724.
    Not heating, element and the stat in the base close to the mains filter both OK, wiring seems sound, possibly the control timer, unless anyone knows of specific faults on these.
    Suspect it may well be obsolete now. 🙁
    QUICK FIX
    Re: AEG AKO446 (old) D/washer
    IS THERE ENOUGH WATER IN IT AS THE SIDE TANK CLOGS UP OR A BROKEN WIRE IN THE DOOR HARNESS GREAT DISHWASHER IN ITS DAY
    #363215
    Filling OK and wiring looks fine.
    I’m guessing the chances of a wiring diagram are not good.?
    QUICK FIX
    SORRY CANT HELP YOU WITH THAT WOULD BE UNUSUAL FOR TIMER NEVER REPLACED ANY OVER THE YEARS FOR THAT FAULT IS THE FAULT ON THE NEUTRAL OR LIVE SIDE WILL ASK AN OLD COLLEGUE OF MINE TOMORROW AND SEE IF I CAN COME UP WITH ANYTHING OK
    #363217
    Thanks for that…
    PS, try switching the CAPS LOCK off. 😉
    Criscold
    I have wiring diagram + manual but only problem is that manual in German only
    Colin
    #363219
    Sadly all bets are off, customer just phoned to say they have decided to replace it. 😥
