Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › AEG Arctis Freezer PNC 922046256 Alarm & Little square
- This topic has 6 replies, 2 voices, and was last updated 16 years, 6 months ago by
dannahaz.
October 7, 2009 at 10:10 pm #49172
dannahaz
ParticipantHi,
We have one of these freezers, side by side with the matching fridge. It’s 4 years old. About a week ago, the freezer started to sound a quiet alarm, and the temp display showed a small square in the bottom left hand corner. Turning the freezer off then on again and cancelling the alarm temporarily fixed the problem.
It then started to do this at least once a day, often more. We had a smilar problem a year ago with the fridge. and changing the sensors fixed it.
We’ve had the AEG recommended engineer out today, he swapped the sensor in the freezer. This evening, it happened again.
The manual is useless, and I’m not sure what we could try next. My husband is very handy and would be able to change anyhing that needs changing – we just don’t know what to try next.
Any ideas please/
Thanks for any help you can giveEDITED TO PUT PNC NUMBER IN TITLE> MODEL NUMBER IS 75248-GA1 (aka 75578KG1)
October 10, 2009 at 8:33 am #298963TheSpinDoctor
ParticipantRe: AEG Arctis Freezer 75248 9755780) Alarm & Little sq
Can you please check the freezer product number as the model you give shows 12 different version. It will begin 922……..
October 10, 2009 at 8:57 am #298964dannahaz
ParticipantRe: AEG Arctis Freezer 75248 9755780 Alarm & Little sq
Hi, thank you for your reply.
The PNC is 922046256
Hope that helps.
October 10, 2009 at 7:31 pm #298965TheSpinDoctor
ParticipantRe: AEG Arctis Freezer PNC 922046256 Alarm & Little squa
Hi.
Which sensor was replaced as there are 2. One is an air temperature sensor, the other is the evaporator sensor.
Any idea?
October 11, 2009 at 8:48 am #298966dannahaz
Hi, thanks for your help.
The service engineer expected there to be two, but when he opened the freezer up he said there was only one and he replaced that.
I’ve still got the bag the new part came in, it says “probe, air”, and the part number is 208 56 11-09/9.
EDITED TO ADD: I’ve just found the explosion diagram on the AEG website, and it appears the engineer was mistaken; I can see from the shape of the part he’s removed that there are two of them, an air one and an evaporator one.
I presume the next step is to buy an evaporator sensor and replace that?
Thanks again
October 11, 2009 at 9:03 am #298967TheSpinDoctor
dannahaz wrote:I presume the next step is to buy an evaporator sensor and replace that?
I would also have to come to that conclusion.
Good luck.
October 11, 2009 at 9:05 am #298968dannahaz
Thanks for that.
DH is opening up freezer now to have a look, and then we’ll order a new sensor tomorrow.
I’ll come back and confirm it’s fixed it (or to ask for more help) as soon as we’ve fitted the new one.
