AEG B1180-1 oven suddenly not working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG B1180-1 oven suddenly not working
  • #31155
    Bong
    My AEG B1180-1 oven has suddenly stopped working .led lights on front have gone…checked the mains plugs and changed the fuse,,but still dead…could some=one help me with some advice 😕
    #229927
    Re: AEG B1180-1 oven suddenly not working
    Some sort of cut-out failure or perhaps the timer. There are too many models in this range – can you post the PNC number, please.
    Bong
    where do I look for that and thanks for the reply
    #229929
    Bong
    right…found it…its 944181727
    #229930
    OK, as far as I can work out, there is no specific safety shut off on this appliance. Therefore, you’re looking at a problem with timer selection.
    Due to the (ouch!) price of this component, I would seriously suggest you get some help with this. It may be as simple as burnt-out wiring or the unit itself may have failed.
    Power off if you wish to investigate for yourself.
    Bong
    ok thank you very much
    #229932
    Bong
    oh and what kind of OUCH would I be looking at if it is that problem?
    #229933
    Part number for timer is 3871247-00/7, but I can’t find a price on it. £100 plus is typical though. spares@ukwhitegoods.co.uk should be able to track it down for you if that’s what’s required.
    Bong
    thank you ..ill see if I can get inside and have a looksee
