AEG B1180-4-M Oven not working – EDITED! PLEASE HELP!
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG B1180-4-M Oven not working – EDITED! PLEASE HELP!
  • #31355
    jackieanne
    Hi, it’s now 2.35AM and I’m still looking for help I have again trawled this site looking for information but cannot find the same set of circumstances we are experiencing so thought if I tried editing it once more someone may take pity on me (c’mon penguin, I’m from Yorkshire too). The clock works fine & the oven power indicator light comes on as soon as you switch the light on & fan starts when selected. I cannot find mention anywhere about the clock which when you try to select the oven temperature buzzes & returns to a flashing display of 12.00 pretty much like an electric alarm clock after a power cut. I have also set the timer, selected oven temperature but then although the light comes on ok when you get to the fan you get the same buzz & flashing 12.00. The most regular problem seems to suggest that the oven not heating up is due to a faulty fan thermostat but could someone please tell me if this would still indicate that this is the case or if it could be something more sinister as am desperate to get it sorted.
    Other info: Single electric oven: 17190009
    Product No.: 944 185 402
    TYPE:91 AHB 01 GD
    Many thanks in anticipation
    Jax
    ps: Hubby would be doing the work, I’m just the info gatherer!!
    #230874
    Re: AEG B1180-4-M Oven not working – EDITED! PLEASE HELP!
    Further to your PM, I confess that I am totally confused as to what the actual problem with this oven is.
    I presume you have no heat in the oven? The usual culprit is the fan oven element:
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=103
    The timer has to be either set to manual, or fully programmed (start and finish time) for the oven to function.
    The flash from the thermostat mentioned in your PM may just be the contact points opening and closing – it does not nesseccarily mean that the oven thermostat has failed.
    The only way to be sure is for hubby to chase the circuit round with a test meter – with the power off – and see what is happening. Anything else is guesswork, I’m afraid.
    jackieanne
    Many thanks for reply. I wonder if I have over done it by trying & failing to describe the problem clearly? 😳
    Just to clarify; neither the oven or grill are heating up (I had not previously tried the grill)
    1) Oven on manual setting & clock set at correct time
    2) Oven function control knob to desired function ie. a)light – ok
    b)ventitherm fan operated cooking (ring element, fan)
    c)fan controlled defrost
    d)full width dual grill (grill, top heat)
    Oven power indicator light comes on
    3) As soon as temperature selector is turned (when function control selector is set on b or d above) the clock loses the set time and display flashes ‘12.00’ which stops anything working.
    Could you please tell me if this makes a difference & helps to diagnose the problem?
    Kind regards
    Jackie
    #230876
    Right – the clock/timer unit is dropping out under load is what you’re saying. The unit will almost certainly be faulty.
    Due to the expense of the component, this is the point at which you get a pro in to investigate properly. There are other possible causes and they all need to be thoroughly checked before lashing out over £100 on a timer unit.
    jackieanne
    Many thanks, have requested UK Whitegoods engineer and now awaiting contact. 😕
    Regards
    Jackie
