AEG B2100-4 oven
  • #98470
    Ski64
    Hi I have an AEG B2100-4 oven that switches on and heats up then turns off after about 10 mins .
    Fan within over working however the front facia gets extremely hot prior to oven switching off.
    Anyone any idea of a fix and is it something easily fixed for a novice !
    cheers David
    #472474
    Ski64
    Further info I just realised the fan at the top that sits behind the facia is not running.
    I compared it to the other one I have as we have 2 side by side.
    Is this easily accessed ? Could it just need cleaned or Is it triggered by thermostat?
    #472475
    think i know what it may be but to confirm i need the complete pnc number from the label
    Ski64
    Hi Dave,
    the number is 944 185 200.
    Do you need any more info?
    #472477
    Ski64
    Brilliant cheers Dave , is it an easy fix ? Access via top of unit once removed from carcass?
    #472479
    very easy fix you can see the pic of where the part fits on the site link i posted
    4 wires 2 blue , 2 white does not matter as long as you connect blue and white in correct postions. both blues are the same so are the whites
    Ski64
    Brilliant mate cheers will let you know how I get on
    #472481
    Ski64
    Parr arrived this morning and 2 mins to swap over.
    All seems to be working fine as secondary fan kicks in.
    Really appreciate your help Dave
