I am hoping someone out there can advise as to which part I need for my oven. The oven works for about 30mins and then cuts out including the fan then after abt 20mins or more it will turn back on and continue for another 20-30 mins and cut out again, this is the process I have to go through.
you need the thermal cut-out located behind the control panel it is wrapped amongst the wiring to the selector switch it has four wire’s coming off it. Electrolux part number 8996619273569
