My AEG oven seems to have a thermostat fault. It operates correctly for about 10-15 minurtes, controling to the required oven temperature. However, after that the oven element will not turn off, even when I turn the right hand temperature knob down to zero.
Has anybody else had this fault, and if so, is it easy to fix myself? I assume the thermostat is faulty.
