AEG B4101-4 FAN keeps running after being turned off
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG B4101-4 FAN keeps running after being turned off
  • #33837
    drkettle
    Hi I have a AEG B4101-4 when the fan operated cooking has finished and switch is turned off the FAN continues to run and will only stop when power is turned off, has anyone had this problem and how can i fix it, it would seem that the thermostat may have blown.
    Any Help appreciated Dave
    #240271
    Re: AEG B4101-4 FAN keeps running after being turned off
    Cooling fan or cooking fan?
    drkettle
    Hi its the fan at the rear of the oven that circulates the air when cooking
    Is this enough Dave
    #240273
    As far as I can tell, the oven fan switching is a function of the selector switch, not the oven thermostat. You’ll need a test meter and the nouse to use it to check. Failing that, use the link below for a UKW engineer in your area.
    Power off, if doing this yourself.
