I have checked the forum for similar faults – apologies if I’ve missed this one.
Our 2 year old oven seemed slow on conventional cooking so I tried the fan cooking setting. Result: no heat at all. Presumably all of the ‘conventional’ heat was being produced by the ‘bottom heat’ element. The fan runs OK. Is this likely to be a fan element failure, in which case:
1. What part do I need?
2. Is it a reasonably easy DIY job? I’ve mended most things over the years.
I’ve read in these forums about a cooling fan switch failure causing problems, but this doesn’t seem to be the same fault.
Relevant numbers are
PNC 944 181 751
Typ 91 AGF 04 GE
Thanks, Jon.
