Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › aeg built in dishwasher. favorit 4001ov1 911935627/04
- This topic has 8 replies, 3 voices, and was last updated 3 years, 11 months ago by
adv.
April 19, 2022 at 4:22 pm #100750
adv
Participanthi guys weird fault this door keeps opening tried adjusting catch still same . its like when water goes to top arm it pushing door open . i took the spray arm off the top basket , and it stayed shut ..its got that rubber bellows at end of the spray .poored water down spray arm and its leaking water where arm spins .. am thinking a new spray arm ? or is it somthing else daft ? a mean what keeps the basket and spray arm pushed up at back .where water comes in the door ?:rolleyes:
April 19, 2022 at 5:01 pm #482060Hollytree_Technical
ParticipantI assume that you have checked the door hinges? The door should not open beyond 90 degrees, if it does then the hinges are bent and that can cause the door to pop open (it doesn’t take much of a bend either).
Jem
April 19, 2022 at 5:41 pm #482061electrofix
Moderatorhave you checked the hinge has not been bent ever so slighlty so the last inch when the door closes it act like a spring trying to pull open the door
April 19, 2022 at 6:20 pm #482062adv
Participanti didnt noticed the hindges being bent more than usual tbh. its this spraying of water against top . only when goes through top arm . i can see it trying to push open . it eventualy does..when take spray arm off its , fine
April 19, 2022 at 6:33 pm #482063adv
Participantjust contacted cx says door doesnt fall past horizontal ..and stiil a slight bit of effort to push dishwasher door alway down .
April 19, 2022 at 6:37 pm #482064electrofix
Moderatorwhen door closed how much effort needed to pop it open ?
also when we are talking bent hinges we are not talking a lot only enough to put pressure on catch when closed. so may not show much below horizontal. you can tell by the feel when door closes the last inch
April 19, 2022 at 6:40 pm #482065electrofix
Moderatorinterestingly the door lock is decribed as having a stronger spring
part no 1526377161
April 19, 2022 at 6:48 pm #482066adv
Participantelectrofix wrote:have you checked the hinge has not been bent ever so slighlty so the last inch when the door closes it act like a spring trying to pull open the door
you mean hinges ie both sides ?or metal catch that door interlock catches on to ?
April 19, 2022 at 6:55 pm #482067adv
Participantelectrofix wrote:interestingly the door lock is decribed as having a stronger spring
part no 1526377161
its 12 years old i noticed it mentioned stronger hinges . for heavy door panels ,, .mmmm cant be that after 12 years..you hear water pushing against the door at top when switches to top arm .. i take spray arm off . can hear water splashing at top like a jet .. but stays shut ok …. mmmm its as if the basket is getting pushed forward maby ? but arms go round fine , and cleaned holes .. should you get any water coming out where the arm swings round . ie where clicks on to spray arm ?as put whole arm on end off tap .. seems water coming out of where it spins round :rolleyes:
