AEG Built in fridge stopped working
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum AEG Built in fridge stopped working
  • #14879
    ambmal
    Hello.
    I would like to ask your advice about my AEG Santo 1700i built in fridge. It is built in to our kitchen above a built in AEG freezer (separate appliances). I switched off the power (at a wall switch, connected to the plug behind the appliances) and defrosted the freezer, cleaned both and switched back on. The freezer is working, but the fridge is not doing anything (although the interior light is coming on).
    As the fridge is approx 20 years old, I wondered if it made economic sense to spend money on an engineer callout (£40 – £50). I wondered if it was the thermostat or relay, but I am not good at DIY so wondered if you could advise me on the likely cause of the breakdown and if appropriate, how easy it would be for a novice to repair?
    Thank you very much.
    #161144
    Dave_Conway
    Re: AEG Built in fridge stopped working
    Very possibly the thermostat.
    Can you find the number beginning Enr please from the rating plate inside the fridge, I’ll check if it’s still available
    #161145
    ambmal
    Hi Dave,
    Thank you for the very prompt reply.
    The number is:
    E-Nr . 621 317 802 F – 076021295
    Malcolm
    #161146
    Dave_Conway
    It is still available, part number 8996711503152 at £28.74 inc VAT and carriage.
    I can order for you if required, an email to spares@ukwhitegoods.co.uk
    If you’re unsure of fitting and diagnosis I would suggest an engineer, check the repairs@ link below 🙂
