AEG built in fridge with electronic control (A headache job)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG built in fridge with electronic control (A headache job)
  • #22548
    Electricmalc
    Aeg Santo K81240i PNC923415415 ser 20427175
    Made a call to a fridge with internal light flashing when door opened. Thought would be easy job (loose connection or switch). But not to be !!
    Electronic control on this one, no ordinary light switch, turns out to be magnet on door and reed sw on PCB. Customer complains that sometimes when door opened the interior light and the temperature display flash rythmicly (spelling) on and off. This may last for just a few seconds or several minutes, and not every time the door is opened.
    Had a look on the service manual for this fridge on Electrolux DVD and no mention of this being any warning or fault indication.
    Has anyone had this fault B4, any help appreciated.
    Malc
    #195459
    cab
    Re: AEG built in fridge with electronic control (A headache
    is the fridge working ok otherwise? if so it would appear the board isnt sensing the magnet, if you look at the service bulletins on tds there is one which relates to poor magnets, there is one also for mixed up buttons on board!!!!
    cab
    #195460
    Electricmalc
    No complaint about fridge not working properly.
    I did miss the service bulletins, thanks for drawing my attention to them, have now read them, and it appears the new magnet is for lights that don’t turn off when door is in closed position. So still stuck on this problem.
    Thanks for your reply Cab
    Malc
    #195461
    lfcjoey
    unfortunately a new board is required, light will flash mainly when compressor is running if left the supply to compressor will be lost and then obviously no cooling.
    #195462
    Electricmalc
    Thanks for your help Ifcjoey, I guessed it probaly was going to be a board problem, will give customer the bad news.
    Cheers
    Malc
    #195463
    Simon46
    Did he go ahead with repair? is it the PCB 2262267558? I have one doing the same.
    Regards
    S.
    #195464
    Electricmalc
    No they didn’t bother with the repair, so can’t say if the board would have cured the problem.
    Mechanical stats used to be easy and cheaper to replace, 😥
    Malc
