AEG “Clicking” washer
  • #27566
    trotter
    Any help please………called out to an aeg washing machine, not filling & making load clicking noise. I see there is a device connected to the solenoid with some plastic cogs inside!
    I am guessing that this is to move a flap in order to direct the water to the right part of the dispensor – the cogs are intact, so is it likely that the “Flap is jammed?
    Any help gratefuly receivd as ever
    Model number to follow!!!
    #214711
    Bryan
    Re: AEG “Clicking” washer
    Water Distributor (top of soap box etc) has to be replaced as a complete unit. About £35+vat trade from memory. You’ll get the part from any supplier once you get the model no.
    Bryan
    #214712
    agree had this fault a few times very common
    Make sure you order on the pnc – there are two different ones – two connector blocks and three.
    Lawrence
    Penguin45 wrote:Make sure you order on the pnc – there are two different ones – two connector blocks and three.
    I got caught by that once 🙁 I have done loads of these must be the hard water in my area or something .
    Lawrence
