AEG Competence 2040B oven switched itself off
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG Competence 2040B oven switched itself off
  • #29001
    onegog
    The fault occurred after AEG Competence 2040B build-in oven was on for 10-20 minutes on grill and the oven door is opened. The bulb in the interior light blew out and oven heat went off. The clock was still on. After a period where everything cooled down it still doesn’t work. I will appreciate any advice. Thanks
    #221049
    Re: AEG Competence 2040B oven switched itself off
    I would imagine that the safety fuse has tripped. This is is a long wire clamped to the front outside top of the oven box. You will need to remove the oven from the casing and test with a multimeter to verify.
    P/no is 8996611846-51/7; spares@ukwhitegoods.co.uk will get you one quickly.
    Power off if you plan to do this yourself.
