Hi everyone,
Heating fan, elements and light of AEG Competence 3201B stopped working after using the grill with fan setting. Cooling fan and pilot light stay on all the time, when oven is turned on. Red light is off all the time. Oven won’t heat at all. We tested thermostat by isolating it from circuit and nothing changed, so we don’t think thermostat is the cause of the problem. Cutoff fuse under cooling fan looks fine, but we think that might be the faulty bit. Clock is working fine.
I would be grateful for any advice as to what you think the problem is and which parts we need to replace.
Thanks in advance.
