AEG Competence 5120B
  • #40742
    HungryJack
    Help please – I am geting hungrier !
    I have an AEG Competence 5120B Typ 56 BBI 36 KO
    The oven will not heqt neither is the light coming on. The clock is set fine and the top fan is blowing air out between the oven door and the fascia.
    Everything was working fine until the missus reckons the kids messed with the buttons under the clock !?! It has not tripped the circuit breaker.
    Any ideas what my problem might be ?
    #267388
    Simon46
    Re: AEG Competence 5120B
    Does it display auto in the clock or an A? Oven will not come on if this is so.
    S.
    #267389
    HungryJack
    Hi Simon, thanks for the fast reply. I have just the time displayed on the clock. e.g. 14.39
    I have cut the power and reset the clock twice but still no joy.
    HJ
    #267390
    Davecas
    does the clock have 4 buttons, 2 either side?
    if so is there an illuminated segment against any of the buttons?
    david
    #267391
    HungryJack
    Hi David,
    there are 6 buttons below the clock display :
    A bell symbol, “¦—->¦” , “—->¦”, A hand symbol , “-” and “+”
    The manual says that to set the clock you depress both right hand arrow buttons together and use “-” or “+” to adjust the clock. This I have done and the clock is keeping the correct time.
    HJ
    #267392
    Davecas
    I cannot find the model you have posted!!
    there should also be either a enr number or pnc number on the label
    starting with 611 … … (9 digits) or 944 … …
    can you please post that number
    thanks
    #267393
    HungryJack
    Found it
    KD 944 181 009-096/922418
    Cheers, HJ
    #267394
    Davecas
    thanks for the enr no.
    have you tried pressing the hand symbol?? (4th button)
    if this makes no difference I suspect the problem may be electrical.
    you say the cooling fan runs? is this coming on all settings or only the grill
    I believe the cooling fan normally only runs on fan oven when it has reached a certain temperature?
    I do not think it is clock problem.
    sorry.
    david
