AEG competence 5212 main oven problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG competence 5212 main oven problem
  • #43065
    uknessie
    I have a strange problem with the main oven, when it is on fan setting there is no heat but on all the other settings the element is fine. can anyone help with an answer, it may be a thermostat but i cannot be sure. ive tested the element and on all setting apart from fan there is supply, as soon as the fan is put on no voltage
    thanks in advance
    #275907
    Re: AEG competence 5212 main oven problem
    Are you sure you dont have more than one element? Often 2 (1 top and one bottom) for the convection setting and a thrid element around the fan. Sounds like the fan element may have gone. You need to post the correct model number (starts either 611 or 911) for any further info.
    #275908
    uknessie
    thanks for that answer, i did wonder if that was the case. i will check again tonight and let you know
    #275909
    uknessie
    thanks for the reply, it has got a seperate element so i will get one and replace
    #275910
    smartin
    couldnt find a 5212 but if its like a 5210 then just the fan symbol is for defrosting and doesnt turn the element on, i take it its an oven thats new to you ?
