Having a problem with the AEG competence 5308 B-D.
The oven works fine normally, but when cooking with the fan only cold air is blown around the oven! Had a quick look around on the forum and found info about fan element issues, but just wondering if it would be the same for this model.
Be advised that fitting involves removing the oven from the housing (It’s damned heavy!) and removing the rear panel. If you are uncertain how to proceed, you must get pro help.
