AEG Competence 94417156100 cuts out during CaTa cleaning
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG Competence 94417156100 cuts out during CaTa cleaning
  • #97731
    Viking2
    Good afternoon. The above used to cut out when both top and bottom ovens were in use at the same time. (Awkward on Christmas Day to say the least but an issue we could live with) Now it cuts out during the CaTa cleaning sequence. I’m aware that the temperature is high during this process and that the high temperature is causing the cutout but I wonder whether anybody has had similar on this model. It is housed and the cooling fan is rotating as it should as this is visible from the front of the unit. The clock etc stays on but the main oven light goes off till the temperature cools down whereupon the oven is again usable. Can anybody assist? Is there a fault code system on this model? Thanks, Harry.
    #469232
    have you checked
    1 the cooling fan is turning at full speed ie not sticking slighly. start it running then turn it off. If it stops abruptly beaings may be sticky
    2 the cooking temperatures are correct
    Viking2
    Hello. The fan takes maybe 10 seconds to stop running when turned off. The cooking temperatures appear correct. How would I test these to make sure? Thanks Harry.
    #469234
    cook temp is easy
    buy an oven thermometer
    https://shop.ukwhitegoods.co.uk/un1470-universal-oven-thermometer
    its also possible the cutout is faulty. if the contacts get dirty or the wire connection is bad it can cause a small amount of heating and coupled with the oven heat can tip it over the edge too early
    Viking2
    Afternoon. So I tried the oven thermometer and hung in from the middle shelf. 180 degrees fan was reading 150 on the thermometer. Does this mean a likely culprit can be identified?
    #469236
    well that does not help if i am reading it right
    you set the oven to `180 but the thermometer read 150
    so that means the oven is cooler than it needs to be so why is it cutting out ?
    i could undertand if ther figures you had were the other way around
    Viking2
    Scrap that. I tried it again and left the oven on for 25 mins this time. The temperature is accurate plus or minus a few degrees.
    #469238
    think i would check the connctions to the overheat stat and change it
