AEG Competence B11880-1. Fan turns off but oven doesn’t.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG Competence B11880-1. Fan turns off but oven doesn’t.
  • #29715
    Armadillo
    When I turn my oven off using the controls, the fans turns off as it should but the oven continues to run at whatever heat I had it set to. The only way I can turn it off is by switching it off at the electric socket, which luckily for me, I can easily access.
    Can someone help with a part name/type/ number that we can get to solve this problem please?
    #224203
    Re: AEG Competence B11880-1. Fan turns off but oven doesn’t.
    Presumably, some sort of thermostat failure. However, your model number doesn’t seem to register on any of my tech info. Perhaps you could check for the “Pnc” number around the door framing? Number normally starting with 9.
    Thanks,
    Armadillo
    Re: AEG Competence B1180-1. Fan turns off but oven doesn’t.
    Sorry, typing error! should be model number B1180-1
    The pnc number is p944-181-727.
    Thanks for such a quick reply.
    #224205
    horndev
    Armadillo wrote:Sorry, typing error! should be model number B1180-1
    I have the part you require, I paid £30 for it but you can have it for £15 plus postage if you want it ? 😀
    #224206
    Armadillo
    What is the part called and what is the part number please?
    #224207
    The oven thermostat is p/no 3301712-00/0 – cost is about £23 plus the usual. spares@ukwhitegoods.co.uk will get you one promptly.
    Horndev, if you paid £45 for one of these, you were robbed………
    Armadillo
    Thanks Penguin45. Will order one very soon.
