AEG Competence B2100-4-m cutting out
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG Competence B2100-4-m cutting out
  • #23596
    Billyboy125
    Hello,
    Thanks to your brilliant advice forum I have deducted that the problem with my oven (just before Christmas!!) is exactly the same symptoms as those relating to the cooling fan thermostat problem. I have had a look inside the top of the oven and found the offending article (two thin blue and two thin white wires) which has burn marks indicating it is U/S. Also there does not appear to be any blast of air blowing out over the top of the door (although the back fan is working when the fault is not apparent)
    Can you advice what the correct part number is please?
    PNC is 944 185 044 and Type is 91AHB 01 GA.
    Many thanks for any help – it seems very easy to remove /or fit.
    Merry Christmas – Bill
    #198737
    Re: AEG Competence B2100-4-m cutting out
    8996619273-56/9 is what you want. spares@ukwhitegoods.co.uk will supply for you. Not in time for Christmas, I’m afraid.
    Billyboy125
    Thanks Penguin.
    Do you have a link for the part on the site as I can’t seem to find it advertised or is it a generic part? We’ll manage over Christmas by blowing a cooling fan at the top control panel of the oven – seems to work ok then !!!
    Bill
    #198739
    Aha – part number supercession – you want this:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=349
    Billyboy125
    Thanks Penguin,
    Thought it was probably that one but the part number was different. Have a great Christmas and thank you for taking the time to reply.
    Cheers,
    Bill
    #198741
    Billyboy125
    Ordered the part from Whitegoods yesterday at about 1pm and it arrived this morning. Have just fitted to oven and everything works fine now. Thanks to Penguin for the initial advice and Dave for the prompt ordering/delivery.
    Cheers and all the best for 2007. Bill
