AEG Competence B2100-4-M Problem pls. HELP!!!!!!!
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG Competence B2100-4-M Problem pls. HELP!!!!!!!
  • #32043
    CJVC
    Advise / help will be appreciated.
    The problem: The oven functions not working, no heat, no lights, no fan. There is power as the clock and cooling fan works. Although the cooling fan seems to be always on despite the oven is cold or not in use. I’ve turned off the power from the mains hoping it will reset, but oven still do not heat up. I am hoping any one can help. thanks, the PNC 944 185 044. Thanks, John
    #233403
    CJVC
    Re: AEG Competence B2100-4-M Problem pls. HELP!!!!!!!
    CJVC wrote:Advise / help will be appreciated.
    Just thought of sharing the solution to the above problem. The thermal cut off kit solved the problem, purchased it over the weekend on this site, arrived today, fit it, now oven is working.
