AEG Competence B2100 cutting out again
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG Competence B2100 cutting out again
  • #92804
    fairviewneil
    AEG Competence B2100-1-M oven in my daughters new apartment worked the first time she tried it but then seemed to cut out intermittently. On a subsequent occasion there was a smell of burning plastic and the lights cut out permanently along with all oven functions, apart from the clock.
    Have researched the topic I took a look inside and found the selector switch had fused/melted on the pins where the infamous thermal cut-out was also connected.
    I ordered replacements for both (although the cut-out looked OK) and having fitted them the lights came back on and everything seemed OK.
    However, after reaching temperature for some time the oven seemed to switch of for a short period again with the lights going out and then coming back on immediately.
    I am worried that there is another fault causing some sort of short circuit or arcing and that we end up back at square on again.
    Any ideas anyone?
    #452257
    Re: AEG Competence B2100 cutting out again
    don’t forget loose connections can also be in the mains connection to the oven. had one the other week and it was the wall switch faulty arcing internally
    fairviewneil
    Thanks Dave,
    Next time I am over I’ll take a look. I did check the obvious (plug) end of the cable but didn’t go further.
