Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › AEG Competence B4100-1 Cooling Fan Keeps Running
- This topic has 8 replies, 3 voices, and was last updated 16 years, 10 months ago by
dodgydodgy.
May 21, 2009 at 11:59 am #45894
dodgydodgy
ParticipantHi,
I’ve an AEG Competence B4100-1 with a problem.
When you use the over after you turn it off a cooling fan runs for several minutes, the problem is that it no longer seems to want to stop. I have to turn the appliance off at the mains, leave it for several minutes and then turn it back on to get the cooling fan to stop.
Any ideas gratefully appreciated.
May 21, 2009 at 6:52 pm #287546Penguin45
ParticipantRe: AEG Competence B4100-1 Cooling Fan Keeps Running
Cooling fan function is controlled a small thermostat on the back of the oven casing. This may well be sticking. Part number is 3873118008, spares@ukwhitegoods.co.uk for pricing and ordering.
Power off if you intend to fit this part yourself.
June 3, 2009 at 9:45 am #287547Albanach
I have a similar problem on my AEG B1180-1 built in oven. The cooling fan does not cut out after use and even after the oven is unplugged overnight, as soon as I plug it back in the fan goes on again. I cannot give the 944 number just now but will follow up later if required.
Can anyone confirm if I require the same part as stated above, Part number 3873118008?
Cheers
June 3, 2009 at 9:50 am #287548dodgydodgy
I went away for the weekend and mine actually fixed itself when I came back and switched it on .. but subsequently it has broken again with the same behavior.
I will check the component above and provide feedback.
June 3, 2009 at 9:59 am #287549Albanach
ParticipantThanks for the quick reply, please let me know as soon as you have found out.
June 3, 2009 at 6:22 pm #287550Albanach
The PNC Number is 944181727 for the above oven.
CheersJune 4, 2009 at 12:00 am #287551Penguin45
It’s got THIS LITTLE DEVIL in it. Usual source of this problem.
Please don’t multi post – we’re only engineers and get confused easily.
June 4, 2009 at 5:37 am #287552Albanach
Sorry about the multi post !
So to confirm I need to replace this part number only
8996619267611? Or do I need to replace this part number as well 3873118008?Thanks for the help!
June 8, 2009 at 8:04 am #287553dodgydodgy
Just to follow up it turned out that I needed “8996619267611 – AEG & Electrolux Oven Cooling Fan Control” and not 3873118008 after all. A least 3873118008 was cheap and the oven is now working.
Thanks for the help.
Simple and a 10-minute job to fix btw (with the power OFF).
