AEG Competence Cooker
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG Competence Cooker
  • This topic has 3 replies, 2 voices, and was last updated 19 years ago by CVT.
  • #25881
    CVT
    I have read all the posts on the problems of both ovens turning themselves off randomly, I have same problem.
    Having looked inside the oven I conclude that the thermostat controlling the coolind fan is the only “Common” component to both ovens?
    So could someone please tell me part number for this sensor and where to buy it – Thanks in advance
    The oven is AEG D81000m
    Product No. 944171128
    Serial No. 03000016
    CVT
    #207950
    Re: AEG Competence Cooker
    http://shop.ukwhitegoods.co.uk/Cooker+{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} … ntrol.html
    That should have a certain air of familiarity about it………
    CVT
    Hi Penguin 45
    I have rec’d the thermostat/sensor ( part # 8996619267611), taken out oven, BUT its the wrong part??
    The sensor/thermostat connected to the cooling fan via purple wire is about 20mm diameter x 20mm long and has an oval flange with 2 mounting screws.
    This sensor is marked 45 degree C and number 1642
    Can you advise the part number please.
    I have emailable picture of it + the 2 similar 150 degeeC stats located either side of it. Email address??
    Thanks in advance for help.
    Oven numbers on my original topic are correct
    CVT
    #207952
    Cut-in thermostat – 3115190-06/2 – c.£7 plus the usual.
    Had assumed you’d had a peek inside already………..
