Re: AEG COMPETENCE D2160-1 COMPLETE SHUTDOWN.
Normally, a total shut down would be caused by the safety thermostat on the top of the oven tripping due to an overheat situation. However, if you can switch off and on and get it running again, I’m more inclined towards some sort of timer failure – dry joints or something similar.
Is the cooling fan running? You should feel a draught running over the top of the door.
We need the full model number, BTW – serial number (9……..) would be better, as there appear to be 20 some versions of this machine.
