AEG Competence D4150-1M2 Rattle
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG Competence D4150-1M2 Rattle
  • #51529
    mikerw
    I was hoping for some advice. I have an AEG Competence D4150-1M2. It has developed a rattle over the last few months that has got progressively worse. The rattle starts after the oven has been on for around 15 minutes and persists for about an hour after turning the oven off unless powered off at the mains.
    I have tried replacing the fan motor with the relevant part (Model: 3115211017) assuming that the fan bearings had gone but the rattle has persisted. Any advice as to what to try next?
    Cheers
    Mike
    #308417
    Re: AEG Competence D4150-1M2 Rattle
    Cooling fan or oven fan?
    mikerw
    Just been doing some more investigating and it looks like cooling fan rather than oven fan. Guess that’s why replacing the oven fan didn’t help!
    The noise comes appears to be loudest at the top of the oven, above the grill and happens when the oven is on in non fan assisted mode. Is that replaceable?
    #308419
    Sounds like you have the answer……… 😀
    Cooling fan doesn’t start until the oven warms and runs on afterwards. And it’s at the top.
    They get clagged up with grease – occasionally you can get away with a strip down, clean and lubrication job. If not, the cooling fan is p/no 3370000-41/0 – spares@ukwhitegoods.co.uk will get you one promptly.
    Stay safe – power off if you’re going to do this yourself.
    mikerw
    Cheers Penguin 45
    Will give the strip down and go and try the part if I get no joy with that. Thanks for your help.
    Mike
