Hi Guys my first post here, and hopefully you can help.
I have just replaced the element of the fan oven of the above model oven.
Oven 3 years old.
I now have the following problems.
When switching on the power I get the following codes.
068 followed by 19 1, from a previous posting I believe this is the software number, but could someone confirm as I dont remember seeing it before.
When I switch on the oven and set a temperature it heats up and reaches its target temp and beeps at me. It does not stop heating up so I have to switch it off.
If I dont the clock display dissapears.
If I dont let it cool down it also will continue to heat up even after I have switched power off and the oven is off when I re apply power.
It does this with both the fan oven and the main oven.
Help please.
John
