AEG Competence D81000m – Fan oven no heat
Home Forums Public Support Forums Help And Support Cooker And Oven Forum AEG Competence D81000m – Fan oven no heat
  • #74804
    Balr
    Model AEG Competence D81000m
    Product 944171128
    The main bottom oven when set on the FAN cooking does not heat up. As the elements come on for some of the other options I don’t think it is the elements. It does also have another common issue that it switches off itself.
    There are 2 elements on the roof of the oven:
    Outer element (rectangle)
    Inner element (3 loop)
    I have tried the following tests to see what heats up and what does not to establish what may be wrong:
    Fan setting – Outer element – is OFF
    Inner element – is OFF
    Bottom of oven – is OFF
    Pizza setting – Outer element – is ON
    Bottom of oven – is HOT
    Conventional setting – Outer element – is ON
    Single grill setting – Outer element – is ON
    Inner element – is ON
    regards Bal
    #392958
    Balr
    Re: AEG Competence D81000m – Fan oven no heat
    Is there another element that is hidden behind the back panel by the fan blade that is used for FAN oven setting ?
    #392959
    Replace the circular fan element behind the backplate cover (fan cover) 😉
    #392960
    Balr
    Hi Martin,
    Thanks for the info…thought there may be another element behind the fan plate, attempted the 4 screws from the back cover but only managed to take 3 off the 4th fails to unscrew.
    Thought about trying WD40 on the screen but it’s flamable, not sure if it’s ok to use while oven is off ?
    regards
    Bal.
    #392961
    Clear head of screw so a screwdriver makes a perfect fit, tap screwdriver with a hammer to loosen rust/corrosion. Then try unscrewing again. (Better still a powered screwdriver will make light work of even the most stubborn screw!)
    #392962
    Martin wrote:Clear head of screw so a screwdriver makes a perfect fit, tap screwdriver with a hammer to loosen rust/corrosion. Then try unscrewing again. (Better still a powered screwdriver will make light work of even the most stubborn screw!)
    Ensure the oven power is fully isolated first, even switch off cooker RCD in consumer unit :zap:
    #392963
    Balr
    Thanks will give that a go..
    regards Bal
    #392964
    Balr
    Hi Martin,
    managed to unscrew the 4th one, all off and tested the element with a multimeter and no continuity, so must be a faulty element.
    Thanks for all you help.
    regards Bal.
