aeg competence electric oven problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum aeg competence electric oven problem
Viewing 15 posts - 1 through 15 (of 15 total)
  • #11517
    I have an aeg competence electric single oven (will need to access paperwork for the exact model). Recently, the oven has started to switch itself off in the middle of cooking. This is a random event as the oven may work for 20mins or over an hour, but generally it will switch itself off. After a period of time, the oven can then be switched back on again. I suspect the thermostat, but unsure as a ‘random’ problem. Can anyone provide some advice/suggestions on how to determine if it is the thermostat and how to replace…
    #145626
    Dave_Conway
    Re: aeg competence electric oven problem
    It sounds like the cooling fan control thermostat but without a model we’re not going to be able to tell for certain.
    Check around the door, there should also be a number beginning Enr or PNC (product code).
    #145627
    gavc_uk
    I have the exact same problem with my AEG Compliance.
    PNC 944 181 726
    Gavin
    #145628
    johnboy
    yes you need a thermal cut out part number 8996619267611. When replacing appliance must be disconnected from the electrical supply.
    #145629
    daveSG
    Hi, Reference to the question from sadamson001
    I have an aeg competence B1180-1 electric single oven, which has the same problem as described.
    Can you tell me if it is the same part number for my oven as listed by johnboy
    Thermal cut out part number 8996619267611.
    Many thanks
    #145630
    Dave_Conway
    It probably is Dave but we’ll need the PNC as above to tell for certain.
    #145631
    daveSG
    Dave,
    The PNC is 944 181 727.
    Is this of some use for the thermal cut out
    Regards
    DaveSG
    #145632
    Dave_Conway
    Yep, it does use that part:
    http://shop.ukwhitegoods.co.uk/89966192 … an-control
    In the shop 🙂
    #145633
    sadamson001
    Thanks for the advice. Part replaced and oven working again!! 😀
    #145634
    sadamson001
    #145635
    Ronmason
    Dave,
    I have a Competence B1180-4 PNC 944 185 665 with the same problem will this part fix the problem
    Regards
    Ronmason
    #145636
    Thermal cut-out kit to fit B1180-4-B Pnc 94416506500 is p/no 8996619273-56/9. Email to spares@ukwhitegoods.co.uk for pricing and ordering.
    As to whether this will cure your problem or not is down to your diagnostic skills – if the symptons are as outlined in the thread, it is not unreasonablle to assume that the part will do the trick.
    Power off of course.
    Tentigers
    mine is a PNC 944 181 727
    Having opened the top of the oven there is a small component in blue shrink wrapped plastic with four wires, 2 blue and 2 white. it is a bit burned. is this the part that needs replacing or is it something else?
    Thanks, Phil
    #145638
    Sounds like it. However, the one that fits your model is p/no 8996619267-61/1.
    Email to spares@ukwhitegoods.co.uk for confirmed prices and ordering.
    Longfur
    Hello
    Same problem with my AEG – PNC 944 181 727. Fitted the replacement part number 8996619267611 – AEG & Electrolux Oven Cooling Fan Control on Sunday and waited with baited breath to see if the oven still cuts out after 30 minutes – and it did. Any ideas?
